2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-12-06T21:13:02+00:00
    PJLTEST, there is a workaround to disable automatic updates.
    Change your internet connection to "metered connection". Instructions here.
    http://www.howtogeek.com/226722/how-when-and-why-to-set-a-connection-as-metered-on-windows-10/
    Here is a summary of that article:
    Click Start>Type wifi>Click Change Wi-Fi Settings>Scroll down if needed and click Advanced options>Click the slider under Set as metered connection.
    You will have to do this on every network you connect to as soon as you connect to it.
    It is a shame that Microsoft doesn't allow Windows 10 Home edition users to disable or at least defer updates, especially when some updates tend to break things.
    2015-12-06T21:33:43+00:00
    Yes, we are all experiencing this issue. Replacing the device won't help. Instead of going through all that trouble, set your system to hibernate only instead of sleep and use battery saver. That makes my SB last up to 8-9 hrs daily use, including Photoshop use.
    2015-12-06T21:48:23+00:00
    Thanks, but it's too late.  Elvis has already left the building.  I use Pro, not home FYI.
    2015-12-06T21:53:53+00:00
    I knew replacing the SP4 was not the solution but I had to go through the replacement process per Microsoft's request to make a point to them, which I did.
    I actually shutdown and avoid sleep all together.  With fastart is takes less than 10 seconds to get back to operating.  Here's hoping for a quick solution.  Maybe it's time to contact the mainstream, non-tech press.  The Los Angeles Times consumer advocate might enjoy tackling this one.
