2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-11-29T07:58:05+00:00
    purchased a surface pro 4 only couple of weeks ago surface pro fan making noises and loud and overheating . not many apps open or programs  open .updated latest software  . room temp about 12 18 c .
    why
    should I return this product .
    2015-11-30T10:42:55+00:00
    I put mine to sleep last night on 33% battery and in the morning it had lost everything and gone into hibernate. It lasted 7 hours according to the sleep study. The drain was 1,600mW, and interestingly enough I had windows hello turned on since I have really enjoyed using it recently. It didn't seem to affect the drain rate for me.
    I have the beta drivers installed which hasn't really made any difference either. I really could do with them pushing out a fix for this, I would love to be able to use the sleep mode.
    2015-12-01T03:20:00+00:00
    I have the exact same problem, the gfx driver causes drain during sleep. I have the SP4 i7
    2015-12-02T21:44:30+00:00
    We appreciate the continued feedback - keep it coming.  Know that we are investigating this and although not part of the 12/3/2015 update we hope to have it corrected in a future update. Please stay tuned.
    Josh
