2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-11-27T18:36:17+00:00
    After my fan came on unexpectedly and no apps running, task manager showed quite CPU and quite bit of memory used by Windows Explorer process. I highlighted and clicked to restart the Windows Explorer process, and the fan immediately stopped. For the Windows Explorer process CPU dropped to zero and memory went down to under 20MB from about 130MB.
    Maybe someone can test whether restarting Windows Explorer before sleep will prevent battery drain.
    2015-11-27T18:54:51+00:00
    I experienced the high fan issue once.  I restarted the device and have not seen this again.  Your experience with a restart of the Windows Explorer process is interesting.  I just restarted the Windows Explorer process and put the SP4 to sleep.  I'll let it sleep for an hour and then run the sleep study process.  I'll post the results when that is complete.
    2015-11-27T20:30:35+00:00
    I restarted the Windows Explorer process and put the SP4 to sleep.  The sleep report for a 1:23:05 duration has a 5 percent of battery (1,837 mWh) energy change.  The two offenders were the Intel HD Graphics (15%) and the CPU C0 Time (11%).  This offenders are consistent with prior sleep periods.  This seems consistent with prior energy changes for equivalent periods of time.
    However, the power meter reports a 9% loss during this time and 9 hours which now changed to 6 hours remaining.  I had attempted to calibrate this yesterday by running the device battery down, and then recharging to 100 percent, but I don't trust that this is accurate.  That being said, the 5% energy change during sleep would mean that the battery would run down fully after 30 hours of continuous sleep.  That's not acceptable.  My Android 4.4 tablet can sleep for two weeks with less than 2 percent battery drain.
    2015-11-28T03:37:49+00:00
    Surface Pro 4's sleep never work well for me. I just get my old Surface Pro 4 replaced because of its defective touch screen. The new one still suffer from battery draining during sleep for Graphics and other causes.
    Whenever I closed the type cover, the system never went cold.
    So I run "powercfg sleepstudy" to find the problem.
    1. Intel HD Graphics was always awake during the sleep. For most sleep sessions, it would up for 30% time, for some sleep sessions, it never went to sleep.
    2. CPU was waked up too, but not as serous as Graphics
    3. The new problem since Windows 10 Threshold 2: Microsoft.Messaging waked system a lot of time, mainly for Skype. I didn't install Skype, this must be the integrated Skype Video and Messaging App.
    I have said it before, and I hate to state it again: Surface Pro 4's sleep mode has no use at all.
