2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-11-27T16:05:41+00:00
    10% per hour is high. The 15/11 numbers you posted in the screenshot are consistent with others here. With all the latest updates and drivers, my drain rate is 16 (GPU)/12 (CPU), about 4% per hour. I'm really hoping it's a driver issue. I reverted to using the display adapter driver from September for now, and the drain rate is a bit better, about 1.3% per hour.
    As to whether or not Microsoft is aware of this and/or working on a fix, .. who knows. They probably figure people don't keep it in Connected Standby for a long time, so it's most likely not a high priority for them. It doesn't prevent us from using the device.
    This is clearly not a hardware issue as it did not occur prior to build 1511 and associated firmware/driver updates.
    I know that Microsoft is working it as I stated in prior threads.  My communications with a Microsoft Engineer (who used to work for me) and the discussion during the incident report troubleshooting on the issue (Microsoft acknowledged that this was a known issue) confirms that Microsoft is fully aware of the issue and is working it.
    I know, I saw the same prior to TH2. That's why I went back to the September driver. As for someone working on it, glad to hear you know someone who is.
    2015-11-27T16:20:59+00:00
    I did not experience this issue until 1511 and associated firmware/driver updates.  If I had the device would have been back in the box and returned to the Microsoft Store where I bought it.  If it is a hardware issue I guess Microsoft will be providing us all with a new SP4!  Oh and those with Surface Books will be getting new hardware too.
    2015-11-27T17:04:32+00:00
    I'm not saying it's a hardware issue ... ???
    2015-11-27T17:37:40+00:00
    I agree. That's why I said "If it is a hardware issue..."  I sure hope it isn't!
    I'll pulse my Microsoft engineer early next week.  When I jokingly told him that I would do information picketing at the Microsoft Store where I bought it to inform others of this issue his response was "I would buy tickets to that."  Haha...
