2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-11-26T15:27:05+00:00
    I'm going to turn off the stay connected to wifi while asleep
    Have you noticed any difference after unchecking "On battery power, stay connected to Wi-Fi while asleep"?
    That's how I always have run (WiFi off during sleep).  It did not make a measureable difference with the energy consumption when I tested with it on, and since my WiFi connects so quickly I've always turned it off.
    (I wanted to answer too although you addressed this to Kent.)
    2015-11-27T14:33:06+00:00
    I just wanted to add that I am also having this issue. I wouldn't call my SP4 hot, but it's clearly running and the battery drains about 10%/hr in sleep mode. Everything is as up-to-date as possible with Windows Update. I've disabled everything I easily can; for a while it was Skype (which I had never even opened) waking it up but that's gone now and Hello has never been turned on. It seems to be just the graphics. I do have a Bluetooth keyboard and mouse but they were several km away during the sleep session in the screenshot I'm posting here. I hope MS can fix this.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=5f51598d-76b3-4490-8acf-7cefb8028701)
    2015-11-27T14:58:15+00:00
    10% per hour is high. The 15/11 numbers you posted in the screenshot are consistent with others here. With all the latest updates and drivers, my drain rate is 16 (GPU)/12 (CPU), about 4% per hour. I'm really hoping it's a driver issue. I reverted to using the display adapter driver from September for now, and the drain rate is a bit better, about 1.3% per hour.
    As to whether or not Microsoft is aware of this and/or working on a fix, .. who knows. They probably figure people don't keep it in Connected Standby for a long time, so it's most likely not a high priority for them. It doesn't prevent us from using the device.
    2015-11-27T15:55:03+00:00
    This is clearly not a hardware issue as it did not occur prior to build 1511 and associated firmware/driver updates.
    I know that Microsoft is working it as I stated in prior threads.  My communications with a Microsoft Engineer (who used to work for me) and the discussion during the incident report troubleshooting on the issue (Microsoft acknowledged that this was a known issue) confirms that Microsoft is fully aware of the issue and is working it.
