2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-11-25T18:11:31+00:00
    How does this not affect the majority of users? I would think it would affect everyone on TH2!
    Anyway, for now, I'm using the display driver dated from September. The drain during sleep is 1%/hour in that case. I posted another thread somewhere here about it.
    2015-11-25T18:18:37+00:00
    Oh, I'm sorry.... I did misread it :(...
    No worries -- we're all just trying to get Microsoft to fix this!
    2015-11-25T21:34:05+00:00
    I tried rolling back on the driver from before TH2; and I'm still getting 4% drain/hour... Very sad :(
    2015-11-26T13:39:21+00:00
    I'm going to turn off the stay connected to wifi while asleep
    Have you noticed any difference after unchecking "On battery power, stay connected to Wi-Fi while asleep"?
