2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-11-23T12:59:52+00:00
    How much loss did you have with that session? 69% is way too high!
    2015-11-23T13:06:14+00:00
    Hmm, and if you go to advanced power settings, you see more than the below?
    2015-11-23T13:11:09+00:00
    Well, I was using it for work, which was mostly OneNote and printing and editing documents. I used it for about 2 hours (maybe slightly less), and it said in the end that I had another 4.5 hours left of usage....
    Well, I had 82% left after 1 hour of work, and 2 hours of sleep, and another 30-40 min of usage.
    I'm going to turn off the stay connected to wifi while asleep
    I have no use for it.
    2015-11-23T13:19:02+00:00
