2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-11-22T23:07:00+00:00
    How do I do a sleepstudy? powercfg /sleepstudy?
    2015-11-22T23:33:08+00:00
    Yes, from an elevated command prompt (run as admin). What I did was add two lines to a text file called "power.bat"
    powercfg /sleepstudy /output "C:\Users<you>\Desktop\sleep.html"
    powercfg /batteryreport /output "C:\Users<you>\Desktop\battery.html"
    Save power.bat on your Desktop. Right click on it and "Run as admin". You'll see two html files (reports) saved on the Desktop.
    2015-11-23T10:47:23+00:00
    You could disable connected standby - that removes the sleep option on the device, which means you're left with hibernate. Or you could set the time between sleep and hibernate to short time. Default is 2 hours. The 8% you see is consistent with default behavior, about 4% per hour. Sleepstudy will more than likely show 16% GPU and 12% CPU.
    Just to inform you, the regedit I did didn't remove sleep mode. I still have sleep mode...
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=9f376408-0dc5-4903-8d39-a909ba57dbb9)
    2015-11-23T10:51:56+00:00
    The .bat was a great idea. I did it, and this is what I got for the top 5 offenders.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=cace8d57-9f4f-4675-b5cd-d4bd7c7bc304)
    Would you recommend looking at anything else in this huge list?
