2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-11-22T20:12:32+00:00
    I would notice the same after a full charge. The first standby session shows no drain. The next goes back to usual 4% for me :(
    2015-11-22T20:15:03+00:00
    I'd like to be able to start with a Surface pro image prior to the Threshold 2 update. I should have saved it. Prior to TH2, my drain rate was better, only 550 mW per hour, as opposed to the 1500 now :(
    2015-11-22T22:37:03+00:00
    Hmm, dinner and a movie. From 8pm to 11:30pm it went down 8%. Stupid connected standby. Has anyone tried this way to disable it?
    Q. How do I disable Connected Standby on a device?
    A. If a device supports Connected Standby, you should take advantage of that capability. Only modern applications that are registered can send a limited amount of network traffic at a scheduled interval, which means Connected Standby generally offers only benefits. However, if you want to use basic sleep instead of Connected Standby, you can disable the feature as follows:
    1. Start the registry editor (regedit.exe).
    2. Move to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power.
    3. Double-click CsEnabled and set to 0, then click OK.
    I'd like to actually get decent battery life from my device :P haha.
    But, thankfully, this time it didn't get warm at all! Before this flash, it would be warm and lose 5% every 5-10 minutes. Now it lost 8% over a period of nearly three and a half hours!
    2015-11-22T22:55:05+00:00
    You could disable connected standby - that removes the sleep option on the device, which means you're left with hibernate. Or you could set the time between sleep and hibernate to short time. Default is 2 hours. The 8% you see is consistent with default behavior, about 4% per hour. Sleepstudy will more than likely show 16% GPU and 12% CPU.
