2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-11-22T01:47:52+00:00
    No difference in drain with the beta driver :( Still see the same GPU/CPU in the sleep report. I know with the July driver that my drain rate during sleep was lower, around 550 mW per hour.
    2015-11-22T08:15:29+00:00
    Well, that was very unhelpful!
    Last night I did an online chat with Surface team, and they said that this is an isolated incident and that 70% of the time they have been able to fix this issue. So they asked to take control of my PC and I said OK. They totally fudged it up. Now I'm downloading the image that Microsoft hosts and I'm just going to start anew. Regardless, just to see, I charged it up last night, and I turned it on and put it to sleep now. I'll come back in an hour. If it's still draining, then the Surface team wasted my time (well over an hour and a half) and now I have to start again.
    Experts my behind... They're going to eat into my Sunday just trying to get my Surface the way I liked it!
    2015-11-22T16:16:26+00:00
    Through what website did you communicate with this Surface team? Did they say how they would fix it? I'm curious to know what it was they were trying to do when they did the remote assist.
    2015-11-22T17:00:04+00:00
    surface.com and then they redirected me to a LogMeIn Rescue applet.
    Mostly DISM and some powershell. They also edited my msconfig and some registry, and disabled all my apps to start up. Something with powershell I imagine ruined it and I couldn't open any app from the store, or even the store. It was sluggish and gave me errors. So... Redid it. Last time I'm letting Surface team take control of my device! Haha. I'm sure they had the best of their intentions at heart, but... Come on... Today I spent 4 hours reformatting and installing everything again.
