2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-11-21T01:17:26+00:00
    I have massive battery drain since November update on my Dell Venue 8 Pro too, I did already a clean install from newest Media Creation iso, without success. It is a perfectly clean install without any software installed, except Windows 10 default apps + Intel driver package for z3700 Atom from Dell's website.
    Drain is about 1-10% per hour in connected standby, where normal drain was always 0.33%/hour under Windows 8.1!! The drain already was always bad under Windows 10 compared to Windows 8.1, but now it is totally bugged and broken.
    I have already tried to disable WIFI when in standby, without success.
    Also tried http://download.cnet.com/Auto-Mute/3000-2084\_4-75110922.html for fixing the Intel audio preventing sleep, without any help.
    For the SP4 owners, just disable Windows Hello, should help a lot for youhttp://www.techradar.com/news/mobile-computing/laptops/surface-book-and-surface-pro-4-battery-life-woes-caused-by-windows-hello--1308020
    On my Venue 8 Pro there is no Windows Hello though...
    2015-11-21T01:42:01+00:00
    It's been mentioned by several people now that Windows Hello does nothing to help. I have never had it enabled and the drain rate in CS is over 1500mW.
    2015-11-21T01:54:43+00:00
    I have just analyzed the drain on my Dell via powercfg, just open a cmd with admin rights, go to c:\temp for example and type in "powercfg sleepstudy" and there should be a statistics html file in c:\temp now which will tell you which processes woke up the device and took how much CPU time while in connected standby. Here is a guide:
    http://blogs.windows.com/windowsexperience/2014/06/26/sleep-study-diagnose-whats-draining-your-battery-while-the-system-sleeps/
    My statistics totally blamed Windows Photo app with 22 minutes total CPU runtime last connected standby... and several other things, a mostly broken WLAN wake mechanism, and oher stuff related to Windows. For example some of the upper programs: Cortana of course, what else...
    Nice thing is you cant totally disable Cortana and it is still totally broken for devices with connected standby and drains battery.
    A normal drain btw is like I said ~0.3-0.35% per hour, which is defined by Microsoft for devices with connected standby.
    2015-11-21T02:49:41+00:00
    I..
    For the SP4 owners, just disable Windows Hello, should help a lot for youhttp://www.techradar.com/news/mobile-computing/laptops/surface-book-and-surface-pro-4-battery-life-woes-caused-by-windows-hello--1308020...
    That assertion is false.  As noted a few times in this forum those of us that do not have Windows Hello enabled still see the battery drain with the majority drain coming from the Intel HD Graphics and the CPU C0 time.
