2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-10-31T12:52:45+00:00
    Having the same issue, has Microsoft commented on this as it is a widespread one?
    2015-11-01T01:55:24+00:00
    Also bought a i5/256 GB Surface Pro 4 and experiencing the same issue. Will someone from Microsoft please comment on how the devices were sold as having a sleep mode which does not work? It uses just as much battery while "sleeping" as it does during use. Mine drains at over 10% per hour while asleep.
    2015-11-01T02:00:33+00:00
    Seems to be an issue with all i5/8GB/256GB models.....I've had two and both have the same problem with the battery draining while asleep.
    2015-11-01T13:35:24+00:00
    It's been found that windows hello is the cause.  Try disabling it and restart.  That should solve your sleep issues, while killing an awesome feature until it gets fixed.
