2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-11-20T21:16:19+00:00
    I haven't heard anything definitive about working on a fix. The last thing I heard from them here was to apply the November 18th update, which didn't help.
    2015-11-20T21:24:47+00:00
    I'm not so sure the 11/18 update isn't what broke this.  I installed the 1511 update on 11/13.  I don't recall noticing the battery issue until I installed the 11/18 firmware/cumulative update for 1511 on 11/18.
    2015-11-20T22:35:34+00:00
    The problem started for me with the Threshold 2 update.
    2015-11-20T22:50:28+00:00
    You may be right, but the overheating for me did not occur until 11/18.  And fortunately it has only done it once and not again.
    Microsoft, JUST FIX THIS!!!
