2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-11-20T20:33:17+00:00
    Keep in mind that you are probably using hybrid sleep and don't know it. What I mean by that is that when you shutdown, you really don't. You'll want to disable Fast Startup if you truly want to shutdown completely, and you will then find that startup is slower.
    Open RegEdit and search for the key CsEnabled - you'll find it, Or
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power
    Change the CsEnabled key from 1 to 0.
    Disabling CS will remove the Sleep option all together, but you will find that you have more options available to you in your power profile configurations.
    2015-11-20T20:42:30+00:00
    Keep in mind that you are probably using hybrid sleep and don't know it. What I mean by that is that when you shutdown, you really don't. You'll want to disable Fast Startup if you truly want to shutdown completely, and you will then find that startup is slower....
    Ah I had forgotten that.  So "Hybrid Sleep" is really what I'm doing which is why the startup time is so short.  I'll keep using that until Microsoft fixes the thing they mucked up with the latest update.
    Has anyone heard anything recently from Microsoft?  The last I read was that they were working it...sigh...
    2015-11-20T20:50:15+00:00
    Looks like you can turn off fast startup in control panel, if desired:
    Power options, choose what the power buttons do, change setting unavailable.
    There is a checkbox that toggles fast startup.
    2015-11-20T21:14:00+00:00
    Right, and what you quoted from me is to disable connected standby, which is a completely different thing. Sorry if the way I worded it came across as the same thing.
