2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-11-20T18:40:02+00:00
    Fingers crossed ! This is getting annoying.
    2015-11-20T18:42:31+00:00
    It's beyond annoying at this stage.  And moderators on this forum are giving some conflicting responses -- some say Microsoft is working on the fix and other act as if there isn't even a problem by ignoring it or recommending installing the November 18th hardware update for Surface.  Maybe they don't have SP4s or don't use them in battery mode.
    2015-11-20T19:19:50+00:00
    It's very common. And Panos, afaict, was lying through his teeth in the keynote.
    With connected sleep enabled, I've never had my SP4 go below 5% per hour battery drain, and after the TH2 update it was closer to 11%.
    I've disabled CS with a registry hack and changed my power settings to hibernate after 5-10 minutes (just in case I close the kbd or hit the power button accidentally, as I have - waiting 25-30 seconds to hibernate and then de-hibernate is kind of a pain if you just forgot one small thing).
    Last night it went from sleep-hibernate and I turned it on this morning and had 97% battery still remaining.
    Can you provide the CS hack?
    I've set my power button to perform a shutdown while on battery.  I've found the power up process is way faster than a hibernate.  I don't leave open work when I stop using the SP4,  so I don't need the advantages of hibernate versus shutdown and then a power up.
    2015-11-20T20:27:32+00:00
    Why is a hack needed to disable connected standby? Sleep can be disabled (change the close lid option to do nothing and sleep time to never) and a hibernate time may also be set.
