2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-11-19T03:25:53+00:00
    I took the latest updates today which included firmware updates for the SP4, and I saw no difference in a 1 hour sleep session. 16% Graphics, 12% CPU. Lost about 1500mW during that hour, same as before.
    Do others see the same?
    2015-11-19T07:27:44+00:00
    That update works for me! Now it consumes only 400mW per hr. CPU 0 and hd graphics are no longer appear on the sleep report!
    2015-11-19T12:42:21+00:00
    It's very common. And Panos, afaict, was lying through his teeth in the keynote.
    With connected sleep enabled, I've never had my SP4 go below 5% per hour battery drain, and after the TH2 update it was closer to 11%.
    I've disabled CS with a registry hack and changed my power settings to hibernate after 5-10 minutes (just in case I close the kbd or hit the power button accidentally, as I have - waiting 25-30 seconds to hibernate and then de-hibernate is kind of a pain if you just forgot one small thing).
    Last night it went from sleep-hibernate and I turned it on this morning and had 97% battery still remaining.
    2015-11-19T13:11:17+00:00
    Yes - the sleep function is all but useless so I have turned all settings to hibernate.
    Means a little slower to boot but plenty of battery left.
    However that does not mean that Microsoft doesn't have to provide a fix be bios or whatever.
