2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2017-04-29T06:48:16+00:00
    Hi BBold
    Mines OK now, I just turned off Windows Hello a couple of weeks after buying it.
    It's a pointless add on anyway so there is no need to replace my tablet, it's just as easy to sign in with either pin or password.
    I guess if Kimberley wants this feature then replacement is her only real option, unless they have brought out another update in the last four months to fix this problem on the newer tabs.
    2017-08-09T13:01:12+00:00
    Hi All,
    Josh
    2017-09-29T06:47:26+00:00
    mine still overheats occasionally when in sleep mode. this happened one time while flying, was pretty alarming to take out the computer from overhead luggage and find just how hot it was. the next samsung note?
    now it is just overheating regularly while running basic programs. about a week ago the fan began firing up constantly. this didn't happen before.
    2017-12-06T13:26:43+00:00
    The overheating problem is back with the fall creators update.
    Since the update my fan has continuously been spinning, and today it briefly turned off (it's a hot day - just under 90 degrees)
