2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2017-02-10T10:38:54+00:00
    Sorry for being extra dumb here but i cannot find how to turn of the "Hello" function in the control panel???
    can someone please give me a step by step solution.
    Thank you
    2017-02-10T20:21:54+00:00
    Hiya Hen
    It's not in control panel. The way I did it was to go to 'change account settings' from the start menu. Then to sign in options. There you will see hello and I just had to hit the 'remove' button. Then voila a Surface pro that I can't use to fry my breakfast cos it no longer gets hot enough, and a battery that lasts longer than 2 hours in use.
    Still think that Microsoft doesn't give a damn about their customers seeing that they are still selling these with this problem. Wished I had waited a couple more months for the release of the galaxy tab 3 but patience isn't something I've ever been known for.
    Hope this helps you
    2017-02-11T11:12:06+00:00
    Thanks - that worked and was easy.
    Now showing 8 hours of battery life!
    Amazing how one program can use up so much juice and Micro Soft won't even tell us about it. I suppose it's their program and they don't want to admit it.
    At least they could come up with an option to only have it working when connected to the mains. At least then we could have a half-way house scenario.
    Many thanks once again.
    2017-03-28T14:52:48+00:00
    This Morning I Went To My SP4 i5/128/4 GB ram to play some minecraft and my game became very sluggish. My fan got very very loud and my computer got very hot and then overheated. Please help!!!
