2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-10-17T21:52:13+00:00
    True... I do not recommend anyone buying Surface Pro 4. Actually this was a fraud. They sell you a computer for more than 1,500 US$ and promise you will get 9 hrs battery life and now I get 2 or 3 at the most, and the battery drain while asleep... so one always has to charge again... Actually after 10 minutes the battery is already at 80%! this is outrageous. One cannot sell such crap products promising one thing and with such result...
    2017-01-29T15:26:02+00:00
    Hi All,
    Josh
    My Surface 4 is updated but continues with the issue.
    2017-01-29T15:30:29+00:00
    Through lots of trial and error, I think I found the problem. It's Windows Hello. Turn it on: get 5 hrs of connected standby. Turn it off: get 87 hrs of connected standby. You can turn it off by using the 'remove' option in the control panel. _Make sure to restart your machine after turning Hello off!_
    Take a gander:
    Without Hello is the same.
    2017-02-09T21:47:31+00:00
    I can not thank you enough. Was on the verge of returning my Surface Pro 4 which I only purchased a month ago because of the battery life(could never get it more than 3.5 hours for full charge) and running hot issue. Thought I'd turn to the internet and stumbled over your solution. Now it is showing over 9 hours on full charge and even after a lot of use it doesn't even get warm. Why on earth are Microsoft still selling these with such a fundamental flaw when the solution is here? Do the care so very little for their customers? Thank you once again, I'm now not regretting paying such a premium price for what was nothing more than a hand warmer.
