2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-08-18T21:39:38+00:00
    I was having the problem nearly every time I would put the computer to sleep.  I finally set the surface to hibernate when closing the lid, rather than sleeping.
    Since I installed the Windows 10 anniversary update a few days ago, I decided to give 'sleep' one more chance - setting the surface back to going to sleep when closing the lid.  Since that time I have not had one hot-bag incident or any problems with rapid battery drain during sleep mode.  Granted, it has only been a few days, but this gives me a glimmer of hope.
    Let me know if anyone else has had good/bad experiences with sleep after the anniversary update.
    2016-08-18T22:06:23+00:00
    I generally have not had the Sleep problem in any consistent fashion, just sporadically.  But yesterday, I put it to sleep (and had just restarted it for other reasons in the evening), and in the morning, the docked screen was showing a pattern, and my Surface was rather warm, requiring a restart with the power button/volume button method.
    This problem is sporadic so I don't know what to make of it, and I hesitate to return it to the store when I can't demonstrate it.  I am overall happy with it, but I must say, I don't quite trust it like I do my work Dell laptop for going to sleep soundly.
    I'm also noticing it won't wake up with the mouse movement all the time, and I do CTRL ALT DEL to bring up the screen for my PIN.  It's not a restart, but seems like a waking issue.
    2016-10-03T02:01:55+00:00
    I have the same problem with i7/256GB after update. I also noticed that the fan is excessively louder than usually and the battery drains very quickly. It drained 30% of battery in just 20 minutes of use. Also the screen gets extremely hot to use.
    2016-10-14T22:18:49+00:00
    Are there other patches for this problem coming out. Just started having this problem. I'm up to date.
