Thank you very much for posting this! I just bought a Surface Pro 3 and I love it except that I have to use a magnifying lens when I use RDP. The only problem I have with using RDCMan is that my local printers won't show up, therefore I can't print. This is true even if I checked on "printers" and "clipboards" under the local resources tab. Do you know if there's a fix on this or maybe there is something else I should check to make it work. My local printers show up when I use RDP and when printing outside of RDP so I know it's not a printer set-up issue. Would really appreciate your help on this.
Remote Desktop Connetion displays Very Small Icons and Jump Lists on Remote Machine
On my remote machine, the desktop icons, icon titles, taskbar and jump lists are puny, very difficult to read the small font size.
I've tried all of the various display/sizing options in my Surface's control panel, and also the display setting tab in Remote Desktop Connection, and have not found any comnbination that works well on the remote and Surface Pro 3. (Also, the sizing options are not so convenient anyway since a sign out is generally needed.)
I've never had this problem and regularly use RDP on various machines. Are there others with RDP display issues?
2014-11-12T05:28:48+00:00 -
2014-11-12T14:31:16+00:00 Hi,
There is no solution that I've seen as of yet - but I haven't really searched much lately - only "dealt with" the MICRO view of the RDP display when needed. When you use RDCMan - does the resolution mirror a 'standard' view - and just show printer issues?
2014-11-12T17:35:45+00:00 Hi,
Yes RDCMan mirrors the standard rep except that it won't recognize my local printers. Basically, no printers are showing up when I try to print reports. I print checks from the remote computer so I really need to be able to print from rdcman. Like you, I have to switch back and forth from rdc man to rep whenever I need to print and it is not very productive.
If other users have a fix for this issue, o would really appreciate if you post it here since I like my surface pro so I'm trying hard not to have to return it.
2014-11-12T18:14:55+00:00 Thanks for the reply - can you tell me more about the use of RDCman - is that something you loaded ON the SP3 or did you have to load it onto the server? Once loaded on the SP3 - was it complicated to configure etc? I only briefly reviewed it's use - may have even downloaded it - however had no luck in connecting from what I recall.
2014-11-12T19:25:54+00:00 Using RDCMan 2.2 my local printer show up when printing from the remote computer. I have "Inherit from Parent" unchecked under the Server Properties local resources tab.
