Surface Pro 3 external monitor / display port issues
2014-09-04T17:19:34+00:00
I know many people have been having issues with external monitors and the displayport connections on the Surface Pro 3 and Surface dock.  I've been having some issues too, and thought I'd share my config / workarounds in case it helps. I believe the issue is fundamentally with the Surface video drivers getting confused, not the docking station.
My explicit questions are: Is there an easy way to force it to detect new displays?  Anybody have any other suggestions on how to resolve this?  Is there some way to open a formal technical ticket with MS?
My hardware: Surface Pro 3 i7, 256 GB; Surface docking station, 2 HP Z24i displays (1920x1200 resolution each), StarTech Mini DisplayPort 1.2 to Triple Head DisplayPort MST Hub (StarTech PN# MSTMDP123DP)
It's setup as follows: Mini DisplayPort MST Hub plugged into back of docking station, HP monitors plugged into ports 1 and 2 of the hub.
I've had this setup running for about 2 weeks. At first I couldn't get it working, but with the last firmware update in mid August it started working fine.
HOWEVER, just this week I've had issues where I can't get the Surface to detect the displays / output to them when I first plug in to the dock in the morning OR sometimes when it's waking up from going to sleep (like at lunchtime). No amount of fiddling / plugging / unplugging things seems to consistently fix it.  The 'Detect' button in the Screen Resolution window doesn't help.  Doing a shutdown / restart of the Surface also doesn't consistently work. Note that when the Surface gets like this, even plugging the Hub directly into the mini display port on the Surface itself (with it not docked) won't work.
The reason I believe this is a Surface / Windows issues is that when it gets into this state, within the screen resolution settings in windows it often thinks that there is another active display plugged in and will act as such (e.g. lets me extend or duplicate the desktop) - even if I have the surface completely undocked, not plugged into anything. Specifically it says it is a "Display device on: Mobile PC Display" with a resolution lower than 1024 x 768.  See pic below.  This state often survives through a reboot of the Surface.
The general process I usually get to work after a couple tries:
-Use Windows-P keys to set the surface to use only the internal display
-Shutdown the surface and undock
-Unplug the dock and hub
-Plug hub back in
-Power Surface back up while undocked and login
-Dock surface
-Plug dock back in
-I'll know it works at this point because the displays will automatically come on (no need to use windows-P key to toggle them)
NOTE TO FORUM MODS:
Before you reply with your standard questions, know that I've already done all the normal things, including shutdown, check all cables, all updates installed, run the hardware and devices troubleshooter.  I've also checked related threads, such as: http://answers.microsoft.com/en-us/surface/forum/surfpro3-surfdevice/external-display-flicker/1e2b9154-0533-4137-880f-55a90d2d6659?page=1&tm=1409850909719 (Note I've never had an issue with flicker) and http://www.surfaceforums.net/threads/mini-displayport-on-new-docking-station-doesnt-work.10577/ (This isn't an active vs. passive adapter thing.)  Once I get it working it works just fine until the surface undocks or reboots.  It's clearly an issue with Windows / Surface not properly detecting displays.
    2015-11-14T04:40:46+00:00
    If you are using the new docking station why are you still using a DisplayPort hub?  I picked up the new docking station and have not had any issues in almost a week now.  I have ditched the DisplayPort Hub and using the dual displayport outputs that are built into the dock now.
    For reference I am using 2 HP EliteDisplay E221 and the internal Surface display.  This is on a SP3 running Windows 8.1.
    The reason we are still using the stardock device is because the new dock only supports 2 monitors and we use 3 monitors.
    2015-11-13T17:20:46+00:00
    Is this just a docking station for the Surface Pro 4 - I heard that had a different connector for the SP4. Can you verify? Or is this a new docking station for the SP3 and 4 etc? What is the part number that I guess is all we'd need.
    The new docking station looks different than the old SP3 one but it works with the SP3, SP4, and Surface Book.  I am using it with a Core i5 SP3.  The SP3 and SP4 connector is exactly the same.
    This is the dock Microsoft is now selling.
    http://www.microsoftstore.com/store/msusa/en\_US/pdp/Microsoft-Surface-Dock/productID.325725200
    2015-11-13T17:01:14+00:00
    2015-11-13T16:30:02+00:00
    LOL! I was just logging on to see if anyone has seen this on the SP4. That answers that. Now I am convinced that no one at Microsoft is using dual external monitors!
    The new dock has dual DP connectors built in so there is no need for a DP hub anymore.  I have been using it for almost a week like this with no issues at all.
    2015-11-13T16:28:49+00:00
