On your particular issue, try moving the data off of the pendrive and reformat it using the Surface tablet. If the pendrive is a capacity higher than 64GB, try using eFAT as the format.
Surface RT and Sandisk Extreme USB 3.0 Flash Drive
I'm having problem using my flash drive on Surface RT.
recently, 95% of the time, when I plug my Extreme USB 3.0 flash drive into Surface RT, I get no response from the system, the indicator on the flash drive does not illuminate, there is no sound (the sound that plays out of speaks when a USB device is connected), and no drive appears in "my computer".
- I have been using this USB 3.0 flash drive on my Surface RT for over a month, and it was OK before, and i don't really know when exactly it started to act up.
- this is the only USB 3.0 flash drive I have now, all my other flash drives which are USB 2.0 work perfectly on Surface RT, and all my external HDDs work fine as well.
- the problematic USB 3.0 flash drive works fine with my Lenovo T420 and T500 with no problem at all
- if I leave the Extreme USB 3.0 flash drive in the USB port while I restart Surface, 100% of the time the flash drive is detected and recognized and working fine after reboot, but when I reject the drive and plug it back in, no response again.
- I have tried to change drive letter, reformat the flash drive, even reinstalled Surface RT in case it was a registry problem. doesn't change anything.
I have contacted Sandisk and the only response I got was "we didn't test it on ARM based system"...
any help?
Surface | Other
2013-10-11T17:03:26+00:00 -
2013-10-11T16:51:02+00:00 Here other user with the same issue. I bought this USB to have my working docs everywhere I go, and the surface to use office everywhere. I can't use them together both are useless to me... Microsoft please fix this!
2013-09-15T21:19:55+00:00 I can confirm the issues. It is difficult to understand, that the Sandisk Flash drive is recognized after reboot. My external USB 3-harddrive is recognized with no Problems. It must be a Software Problem which MS should solve.
2013-03-26T06:00:29+00:00 -
2013-03-21T20:16:43+00:00 Hi,
thanks for checking! Now that you mentioned it, I remembered that I still have an old usb Extension cable, which seems to work with the sandisk. Not the ideal solution, but it works..
