surface book battery drain while shut down
2015-12-09T16:09:58+00:00
Split from this thread.
I have been noticing that when I shutdown my surface book, when I power it on the next day the battery has drained some. If I leave it off for a couple of days it will drain down from 100% to around 85% or lower.
I disabled fast startup... and then just decided to disable hibernation altogether. That didn't help.
I have windows hello disabled, but that shouldn't matter anyway since I'm shutting it down, not sleeping.
Some searching and I found a general windows 10 issue with the "Intel Management Engine Interface" driver. Some say that v11 can cause this issue. One solution that I have seen suggested is to go into device manager and in the power management tab for this device uncheck the option that allows windows to power it down to save power. I tried that and it didn't help.
Others have suggested downgrading the driver from v11 to v9 or v10, but I don't know where to get v9 or v10 of this driver that is compatible with the surface book. Anyone know if one of the downloads on Intel's site would be compatible?
So, has anyone else noticed this issue and know of a fix?
    2015-12-04T19:07:25+00:00
    I am with you Gary.  I love my SB.
    2015-12-04T19:10:54+00:00
    I love my SB, too. Don't get me wrong. I just want it to work a little better -- last more than 6 hours a day and not be eating battery when the dang thing is turned off. That will not work for me, or most people.
    2015-12-08T01:36:20+00:00
    Was your issue with the connected standby function or the issue that some Surface books still have battery drain when it is completely shut down? Or possibly both?
    Today i lost 10% in battery life after having my computer shut down for 24 hours. Not sleep, not hibernate, shut down. I would show a screen cap of my battery report showing this, but I'm not sure how to on these forums. I just really hope this isn't an overlooked issue because I see a lot of people complaining about the connected standby but there are also users who experience battery drain upon full shut down
    2015-12-08T02:28:53+00:00
    I am not sure of the difference between "connected standy" and "complete shutdown."  What I have noticed on a brand new machine is invoking sleep and put machine in bag -- hours later it is very hot and battery drained down.  Not sure if this is also happening in sleep on my desktop on the charger -- how would you tell?
    2015-12-08T04:06:30+00:00
    Do a sleepstudy and you will see what happened.
