I actually was wondering this myself, if maybe Microsoft is refusing the $200 replacement fee they initially promised to discourage it b/c the problem being software.
Surface Pro 3 LGC Battery Degradation
Split from this thread.
It was suggested that I open a new thread for this issue that I am having.
Since the Win 10 Anniversary update, I was not able to turn on my Surface Pro 3 i7 512GB with LGC LGC Battery without having it plugged in with the power supply or docking (I own a total of Three Surface Pro 3 Docks at home and 2 offices). It always said "82%, Plugged in, Not Charging", and would always instantly turn off once I pulled off the power supply tab.
I had spoke with a Technical Agent online, had my Pro 3 remote accessed, did all the proposed solutions, and even had a call from Bellevue, WA (I live in Hong Kong) before I found out that it was a software issue as stated by Microsoft.
With Auto Update turned on, I was notified that I should restart my Pro 3 this morning while I was on the docking station. I was happy that this issue was going to be resolved, but now I am disappointed that this firmware update did nothing for my Pro 3.
I'm hoping that someone out there has some suggestions.
Thank You.
2016-11-04T11:33:49+00:00 -
Barb Bowman 80,805 Reputation points MVP Volunteer Moderator2016-11-04T10:25:34+00:00 where did you replace it and what did you replace with?
>>The battery is not the problem. It is a reconfiguration issue in windows update. I have replaced the battery and same issue.
2016-11-04T02:38:23+00:00 http://www.geniusphonerepair.com/
Disclaimer, I have not used them, I only went so far as to contact them and learn what the prices were. I cannot vouch for them. If anyone does use them though for this I think we'd all be very interested to hear the outcome.
2016-11-04T02:35:55+00:00 Interesting, so its a firmware issue...
2016-11-04T02:30:09+00:00 The battery is not the problem. It is a reconfiguration issue in windows update. I have replaced the battery and same issue.
