Surface Pro 3 LGC Battery Degradation
2017-02-16T00:04:44+00:00
Split from this thread.
It was suggested that I open a new thread for this issue that I am having.
Since the Win 10 Anniversary update, I was not able to turn on my Surface Pro 3 i7 512GB with LGC LGC Battery without having it plugged in with the power supply or docking (I own a total of Three Surface Pro 3 Docks at home and 2 offices). It always said "82%, Plugged in, Not Charging", and would always instantly turn off once I pulled off the power supply tab.
I had spoke with a Technical Agent online, had my Pro 3 remote accessed, did all the proposed solutions, and even had a call from Bellevue, WA (I live in Hong Kong) before I found out that it was a software issue as stated by Microsoft.
With Auto Update turned on, I was notified that I should restart my Pro 3 this morning while I was on the docking station. I was happy that this issue was going to be resolved, but now I am disappointed that this firmware update did nothing for my Pro 3.
I'm hoping that someone out there has some suggestions.
Thank You.
    2017-09-15T03:04:15+00:00
    At this point i am diagnosing the issue personally to confirm if it is indeed the FW as suspected (something the community was expecting MS to do).
    My device has been sitting on a shelf for over a year now waiting for this issue to be fixed, and MS has made it quite clear through silence that they simple don't care enough to solve the issue.
    I'd rather swap the boards in my 2 devices to find the root cause than to pay ms $600 here in Canada to get a refurb device.
    2016-09-22T19:40:25+00:00
    Greg,
    First and foremost, thank you Greg for responding with an official recognition of the problem.  I hope that you can appreciate from the consumer's end how frustrating the silence was.  We all had the same problem, starting at the same time and were basically being told that we were SOL.  Again, thanks for the update.
    Bilal,
    I'm going to agree with you in opposition to Greg's comment.  My son was playing Minecraft on my SP3 before bed time on battery.  When he shut it down, I had "Updates ready to be installed".  I plugged it in and let it go for the night.  That was the last time it ran on battery.
    So, if Greg is correct, then I think that we are all suffering from one HUGELY annoying and timely coincidence.
    Chris
  3. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2016-09-29T15:52:29+00:00
    1. the support agents in THIS forum don't talk to the people in Redmond and
    would not be in a position to take you up on an offer to send yours in. Greg
    hasn't been back since he made that one post.
    1. I don't know what hardware they already have, but there appear to be two or
    three different issues with LGC batteries.
    1. Your issue appears to be different that the trending ones. I can't see anyway
    you could install firmware - even if there was a fix - in your situation where
    it is 0% not charging. So you should chase a replacement. I have been unable to
    find anyone that will honor the $200 battery replacement promise on Reddit
    https://www.reddit.com/r/IAmA/comments/26m9cu/we_are_panos_panay_and_the_surface_team_at/chsei5u
    • I have contacted everyone I know at Microsoft on this without getting an
    answer as to how customers can get a $200 SP3 battery replacement.
    2016-08-30T16:26:09+00:00
    I also have the issue with LGC battery.
    Before 8/29 update, my SP3 has battery issue, once unplugged SP3 will shutdown within 20 seconds because of battery. After 8/29 firmware update, the problem is still there. Here is the battery report, only 144mWh.
  5. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2016-08-30T15:08:37+00:00
    Got a reply from MS:
    That’s definitely a different problem from what we saw with the Simplo batteries.  I’ll send it back up to the engineering team.
