Surface Book 3 Overheating During Updates and Routine Downloads?
2020-05-27T20:43:15+00:00
First off, the specs are: 13.5"/i7/32GB/512GB/1650 Max-Q
Not sure if this will be the case for all users, but I am currently troubleshooting a issue with the Surface Book 3 going into a thermal throttle state from just restarting or trying to update even basic things.
The first few days were fine - though attempting to run Minecraft didn't actually engage the dGPU for some reason.  Eventually got the dGPU to work by installing NVIDIA's GeForce Experience, or whatever it's called.
Then I noticed that the fan would spin up even when the SB3 should have been in sleep mode; I fixed this by just having it hibernate instead. Since then, I haven't heard any fan noise at all, even when the thermals were hitting well into the upper 90s C and even a few cores hitting 100 C.
Now, I can't seem to cool the thing off. I was trying to install Adobe Acrobat Pro and the latest Intel drivers (apparently one was released on 5/20?) the screen shut off and a little thermometer popped up (which I assumed, and later confirmed, meant that it had overheated and shut down to prevent damage).
Like I mentioned just above, now I can't seem to get the darn thing to run cool enough to even install it's routine updates. I have a box fan pointed on it to try and help, but even that doesn't seem to be effective.
When last I checked (which admittedly was a few hours ago now since I'm trying a factory reset to see if one of the updates caused this) the CPU was capped out at 400 MHz, but it hasn't overheated since. It sure does take a heck of a long time to do a reset when your CPU is capped to 400 MHz.
I'm hoping that this factory reset will fix the issue (hey, ya never know 'til ya try, amirite?), but otherwise I assume that I will likely have to warranty this particular SB3.
Not really sure where I was going with all of this, I guess I was wondering if this is something that could be caused by updates and drivers or if there is a more serious hardware issue.
I spent far too long trying to see if I could force the fans to spin regardless before just giving up on that.
I'll add a link here that has a picture (would've done a screen cap, but it's in the middle of resetting) and some video showing what I'm talking about.
Thoughts or suggestions?
    2020-08-24T14:07:14+00:00
    I feel you and I am in front of the same decision. I use Windows for over 20 years and I have over-average knowledge. And I do not want a replacement device from Microsoft; you can read many feedback according exchange devices in this community. Support from Microsoft according Surface Hardware is imho horrible. Please, Microsoft, show me the opposite!
    2020-08-24T17:36:06+00:00
    I ended up returning my Surface Book 3 and getting a Razer Blade Stealth 13, so sorry, I can't really tell you if it was a device-specific issue or not.
    How did you proceed to return it? I'm only offered support + replacement, but I'm already on my second machine and don't want to spend more time on it.
    2020-08-26T02:31:42+00:00
    I am almost over it too - I've got the Microsoft Complete for Surface Book for my SB3 too and bought direct through Microsoft for WFH replacing my SB1. Overheating for basic browser based video calls and collaboration is just too much to put up with.
    2020-10-19T14:48:55+00:00
    I have the same issue, but only after upgrading to 2004. It worked flawlessly before upgrading. The first time it happened was the night I upgraded to 2004 and it hasn't been able to be plugged in while on since then. It woke me up in the middle of the night spinning and super hot to the touch. It was across the room on my desk. The lid was closed and I had only Outlook and Teams open. When I opened the lid it had a BSOD from overheating. It was plugged in with the stock charger that comes with it. I then ordered a brand new Surface USB-C dock (2), and I'm facing the same issue with it.
    Unplugged, it works fine no matter what I'm doing or have plugged in to the USB ports (including USB-C to DisplayPort 4K monitor, Jabra dongle, and Logitech external keyboard dongle. I also have a Bluetooth Surface mouse connected). Any time it's plugged in to power for even 5 minutes - it starts heating up like a hot plate. I've been shutting it down to charge it, then working until it dies....I'm sure my employer will understand....
    All updates are installed. Current branch M365 Apps.
    2020-10-19T16:12:20+00:00
    Selecting the "Recommended" Power mode seems to have mitigated the overheating issue for me. It was previously set to "Best performance" when plugged in but "Recommended" when unplugged (I have never experienced the overheating issue while unplugged), so I thought it was worth a try based on feedback on the Surface Book 2 found here: link
