Surface Pro 3 - completely dead
2017-12-08T22:23:24+00:00
My Surface Pro 3 has died after two years, I've tried all the 'wake-up' fixes, still nothing. Very unhappy if this needs to be replaced, it seems a lot of money for two years use. Can anyone help or suggest a reasonable repair service in Central London?
    2017-12-08T23:14:08+00:00
    if you do a search you will see this question asked many, many, times.
    with no real answer as to the cause.
    or a permanent solution.
    you will find several suggestions to try with the most common being the ON 30", Vol+ ON > 15" routine which I am sure you have tried.
    this is my experience:
    1. I had the issue about a year ago and the Vol+ ON worked for me and then I forgot about the issue cause it never returned until...
    2. after a recent update the problem came back. wouldn't wake, and twice turned itself off while in tablet mode. nothing worked to wake it.
    3. one day I played with it for hours trying different combinations and it finally woke!
    4. I went into power settings and told itNEVER to sleep.
    it has been fine for about a week now.
    I turn it off several times a day and it starts again ok each time. I just don't let it sleep.
    There has also been another MS update. coincidence?
    this is my current thinking:
    • it isn't broken
    • it isn't the battery or a hardware error
    • it is a software error
    • it might be due to MS updates
    • a clean install might fix it, stop it from recurring, haven't tried it myself
    would be great if MS could solve this.
    2017-12-08T23:43:31+00:00
    This seems to be a major issue. yet Microsoft cannot be bothered to fix the problem. I suppose greed wins and in-built obsolescence is a money stream for them.
    2017-12-09T00:43:54+00:00
    I don't think it is built-in obsolescence per se. More likely ineptitude and poor values.
    We see it in everything these days. Poor quality build/premature release where marketing and spin trump engineering.
    2017-12-14T21:52:16+00:00
    Exact same situation for me.  I had mine for 2 years and 1 week.  Tried everything.   Very disappointing.   Good thing we have the Microsoft virtual assistant to solve our problem.   With an obviously common problem you almost think they built a 2 year bug into the system to try and sell more units when they die.  Time for Apple?
    2017-12-15T21:17:23+00:00
    I finally got the bl00dy thing going!
    Unbelievably, if you slightly bend the Surface in whilst holding the power key down it will start up. It takes a few goes, but it stayed on long enough on one occasion for me to go to settings and select NEVER SLEEP.
    Microsoft, you are a disgrace, you wanted nearly £500 for a replacement, I'll never buy a Microsoft product again, you are no better than a snake oil salesman. Your silence on this issue is shameful.
