Surface Pro 7 charger randomly stops working
2020-12-14T00:43:01+00:00
I bought my Surface Pro 7 about 5 months ago and the charger has been giving me problems for about a month now. It only sometimes charges and it seems to be random when it does. I have to plug and unplug the charger multiple times in multiple outlets around the house in order for the Surface to recognize it, and when it does I have to leave it be because if I move it in any way, it stops charging again.
Please if anyone has had this problem or has anyone knows what I could do, it would be appreciated. Not sure if the problem is the charger but it is very frustrating since the device is brand new and I haven't even used it for a year.
2020-12-14T16:57:23+00:00
Hi Patricia Candelario,
Thanks for reaching out to Microsoft Community and posting your inquiry.
To verify if it's a problem with the charger or the charging port, we suggest the following:
• Try a different Surface Charger and check if the issue is resolve.
• Clean the tip of the charger with a cloth, dirt might be blocking the connection.
• Try the current charger to a different Surface Device.
We recommend following the steps at What to do if your Surface power supply or charger doesn’t work and requesting service if needed.
Kind regards,
John Neil_J
62 additional answers
    2021-12-21T02:44:13+00:00
    The charging is the least of my problems now. The battery has blown up like a pillow and has caused my screen to separate from the case on the right-hand side. Now part of the screen is flickering...first and last Surface I ever buy, looking for another brand this time around.
    2021-12-24T06:53:28+00:00
    This exact same thing has happened with me. I’m very frustrated.
    2022-01-15T04:34:49+00:00
    I like everyone else has the same issue. But given the time that has elapsed from the first post until now, what I'd really like to know is how Microsoft have addressed this issue? Will they replace the power source for free, given that this clearly is a defective, part. I was partway through an update (make sure all updates are installed in help)when my device died. I am sick, of trying every outlet in my house, rotating, wiping etc.
    2022-01-15T16:51:10+00:00
    Right now the power supply is the least of my problem. Shortly after I had the problem with it not charging the screen began to delaminate from the frame on the right side. Currently its bowed out about 3/8" and enough that you can see inside and the battery looks like an overstuffed pillow. And now about 80% of the screen flickers. I don't dare leave the charger plugged in unattended for fear the battery could catch on fire.
    Needless to say this is the last Surface product I will ever buy.
