Surface Pro 7 charger randomly stops working
2020-12-14T00:43:01+00:00
I bought my Surface Pro 7 about 5 months ago and the charger has been giving me problems for about a month now. It only sometimes charges and it seems to be random when it does. I have to plug and unplug the charger multiple times in multiple outlets around the house in order for the Surface to recognize it, and when it does I have to leave it be because if I move it in any way, it stops charging again.
Please if anyone has had this problem or has anyone knows what I could do, it would be appreciated. Not sure if the problem is the charger but it is very frustrating since the device is brand new and I haven't even used it for a year.
2020-12-14T16:57:23+00:00
Hi Patricia Candelario,
Thanks for reaching out to Microsoft Community and posting your inquiry.
To verify if it's a problem with the charger or the charging port, we suggest the following:
• Try a different Surface Charger and check if the issue is resolve.
• Clean the tip of the charger with a cloth, dirt might be blocking the connection.
• Try the current charger to a different Surface Device.
We recommend following the steps at What to do if your Surface power supply or charger doesn’t work and requesting service if needed.
Kind regards,
John Neil_J
62 additional answers
    2021-09-23T17:53:24+00:00
    Excluding the power supply (which was changed under warranty with the more powerful model ... maybe there were some problems ...), I have been working very well with my Surface Pro6 and Surface Pro7, for 3 years. Excellent machines.
    2021-09-24T22:45:43+00:00
    I have a similar battery issue. The SP7 charges up to full, so no cord or charger issues. When I go mobile, SP7 battery dies within 2 hours, and I am not using any battery hogging apps. So, I have to be tethered to a wall outlet.
    The online support is awful since they will not send my replacement first, which means I would be without a computer for 3+ weeks, and being without a computer for a day is unacceptable.
    2021-10-02T22:51:45+00:00
    Mine is doing the same, just spent ten minutes at it and I'm now using my phone. Been happening for the last 4 months. Very frustrating. Any comment from Microsoft on this issue? 52 replies is surely a know issue by now.
    2021-10-03T11:46:39+00:00
    I cannot see a single reply from micosoft that suggest a worthwhile remedy or any support what so ever.
    I am totally disappointed and am researching a replacement product - anything but microsoft.
