There are many factors which cause the crackling sound on the Surface. Let's sort this out. However, to be able to understand the issue better, can you provide more details by answering these following questions:
• Can you tell us when and where did you purchase the device?
• Did you check if the crackling sound is recognizable with or without the power supply plugged in? Were there any differences?
• What troubleshooting steps have you tried so far?
Let us know so we can help you further.
as for me it is like this:
* I did buy the Surface Pro 4 from the Microsoft Online Store Germany.
* As I already wrote, the crackling sound only appears when the power supply is
NOT plugged in. So yes there is a difference.
* I tried all the steps mentioned in this thread.
So speaking of trying all the steps in this thread:
Two days ago I tried the current version of the Surface Diagnostic Tools. Since then the crackling noise in off mode seems to have vanished. I think it is too early to say "problem solved". I will keep you updated here.
Strangely enough several days ago my Surface suddenly started to have the "sleep of death problem", too. It occurred about every second sleep mode initiation. This seems also to have vanished since the last run of the diagnostic tools.
I will monitor the behaviour the next two weeks and get back to you here.
Kind regards
