Double tap to left click and drag on trackpad
2013-10-25T13:45:34+00:00
Hello, I was trying to find a way to click and drag by using the Type Cover 2 trackpad without keeping the left mouse button pressed. Most touchpads nowadays register a rapid double click as a "left click and drag" command and, according to the documentation on Microsoft's website, the Type Cover 2 should as well. However, I tried to use the feature both in Desktop programs and UI apps with no success. How to left click and drag without keeping the trackpad's left mouse button pressed?
Edit: called the customer service, and I was told that the team is aware of the issue and that a fix is planned.
2014-04-09T01:07:12+00:00
With 8.1 update 1, type/touch cover 2 can now perform double tap-drag. All hail lord Microsoft.
2013-11-21T02:57:03+00:00
Greetings all,
The “Tap, then tap and slide one finger in any direction"  gesture to perform a “left-click and drag” is not supported in Windows 8.1 for precision touchpads such as Touch Cover 2 and Type Cover 2.
The “left-click and drag” function can be performed on Touch Cover 2 and Type Cover 2 by holding the left touchpad button down and then sliding a finger in any direction.
We’ll be updating the inaccurate information in Touchpad: A built-in mouse.
158 additional answers
    2013-10-31T07:16:20+00:00
    Hello.
    I have the Surface Pro 2 and Type Cover 2 and am expecting the ability to TAP-TAP-HOLD-DRAG windows around the screen, but it appears that functionality is not on by default.  Is it even available?  I cannot find it anywhere in Settings or Control Panel.
    Since this is really common touch-pad functionality and the original Surface RT had it, I suspect I'm just not seeing the setting?  I'd appreciate it if you could point me in the right direction.
    Thx,
    ALF
    2013-10-31T13:09:36+00:00
    Just found this thread (second result in a Google search for "Double Tap Drag on Type Cover 2"), started on October 25th ... http://answers.microsoft.com/en-us/surface/forum/surfpro2-surfhardware/double-tap-to-left-click-and-drag-on-trackpad/1d7faa76-971c-455d-8e41-dbf0d529c033
    They've asked the same question. Apparently, this individual has contacted Microsoft Support and they've advised that it's a known issue and they are working on a resolution.
    I hope this helps.
    2013-10-31T16:04:49+00:00
    Thanks!  Sounds like it's not something specific to my Surface anyway.
    Interesting that one MS person at that link says it's known and will be fixed, but the other intimates the opposite.
