Double tap to left click and drag on trackpad
2013-10-25T13:45:34+00:00
Hello, I was trying to find a way to click and drag by using the Type Cover 2 trackpad without keeping the left mouse button pressed. Most touchpads nowadays register a rapid double click as a "left click and drag" command and, according to the documentation on Microsoft's website, the Type Cover 2 should as well. However, I tried to use the feature both in Desktop programs and UI apps with no success. How to left click and drag without keeping the trackpad's left mouse button pressed?
Edit: called the customer service, and I was told that the team is aware of the issue and that a fix is planned.
2014-04-09T01:07:12+00:00
With 8.1 update 1, type/touch cover 2 can now perform double tap-drag. All hail lord Microsoft.
2013-11-21T02:57:03+00:00
Greetings all,
The “Tap, then tap and slide one finger in any direction"  gesture to perform a “left-click and drag” is not supported in Windows 8.1 for precision touchpads such as Touch Cover 2 and Type Cover 2.
The “left-click and drag” function can be performed on Touch Cover 2 and Type Cover 2 by holding the left touchpad button down and then sliding a finger in any direction.
We’ll be updating the inaccurate information in Touchpad: A built-in mouse.
158 additional answers
    2014-05-02T00:31:38+00:00
    Yes, unstable.
    Every time I will reattach the type cover, then it will function well again.
    But in 1 day, reattach it many times...
    Hope someone will figure out a way to "Refresh"  the type cover, somehow a batch file or something.
    2014-06-17T08:43:24+00:00
    Greetings all,
    Has anyone tried this with a Surface RT 1 and a Type Cover 2?
    I simply cannot get click drag to work even with the KB2919355 Windows 8.1 Update 1 package installed.
    I have tested with the same Surface RT 1 and Touch Cover 1 and it works fine.
    2014-06-17T15:50:28+00:00
    Greetings all,
    The so-called "precision touchpad" in the Type Cover 2 products does not support this gesture, or Microsoft has not included support in its drivers.  Type Cover 1 works fine because the hardware is different.
    Virtually every other trackpad device for a Windows PC has supported this for years, decades even. I'd like to meet the program manager who made this decision.  The Type Cover 2 touchpads are painful to use on a good day, but the lack of support for this gesture makes them much worse.
