With 8.1 update 1, type/touch cover 2 can now perform double tap-drag. All hail lord Microsoft.
Double tap to left click and drag on trackpad
Hello, I was trying to find a way to click and drag by using the Type Cover 2 trackpad without keeping the left mouse button pressed. Most touchpads nowadays register a rapid double click as a "left click and drag" command and, according to the documentation on Microsoft's website, the Type Cover 2 should as well. However, I tried to use the feature both in Desktop programs and UI apps with no success. How to left click and drag without keeping the trackpad's left mouse button pressed?
Edit: called the customer service, and I was told that the team is aware of the issue and that a fix is planned.
Greetings all,
The “Tap, then tap and slide one finger in any direction" gesture to perform a “left-click and drag” is not supported in Windows 8.1 for precision touchpads such as Touch Cover 2 and Type Cover 2.
The “left-click and drag” function can be performed on Touch Cover 2 and Type Cover 2 by holding the left touchpad button down and then sliding a finger in any direction.
We’ll be updating the inaccurate information in Touchpad: A built-in mouse.
158 additional answers
2013-10-30T18:51:09+00:00 Yes, one gesture on the list is incorrect. You can not click and drag by doing tap then tap and slide using one finger in any direction. You have to use two fingers to drag or move objects using the touchpad. This is not the case in the original type cover which I have now.
2013-10-30T20:03:52+00:00 Yes, one gesture on the list is incorrect. You can not click and drag by doing tap then tap and slide using one finger in any direction. You have to use two fingers to drag or move objects using the touchpad. This is not the case in the original type cover which I have now.
Yes, same with me. It works on the original TypeCover, and according to the link Steven_B posted the "tap, and tap and drag" gesture should work on the Type Cover 2 also. Hope they fix this.
2013-10-31T03:52:54+00:00 same here. using the typecover 2. tap tap slide does not work for dragging.
