Double tap to left click and drag on trackpad
2013-10-25T13:45:34+00:00
Hello, I was trying to find a way to click and drag by using the Type Cover 2 trackpad without keeping the left mouse button pressed. Most touchpads nowadays register a rapid double click as a "left click and drag" command and, according to the documentation on Microsoft's website, the Type Cover 2 should as well. However, I tried to use the feature both in Desktop programs and UI apps with no success. How to left click and drag without keeping the trackpad's left mouse button pressed?
Edit: called the customer service, and I was told that the team is aware of the issue and that a fix is planned.
2014-04-09T01:07:12+00:00
With 8.1 update 1, type/touch cover 2 can now perform double tap-drag. All hail lord Microsoft.
2013-11-21T02:57:03+00:00
Greetings all,
The “Tap, then tap and slide one finger in any direction"  gesture to perform a “left-click and drag” is not supported in Windows 8.1 for precision touchpads such as Touch Cover 2 and Type Cover 2.
The “left-click and drag” function can be performed on Touch Cover 2 and Type Cover 2 by holding the left touchpad button down and then sliding a finger in any direction.
We’ll be updating the inaccurate information in Touchpad: A built-in mouse.
158 additional answers
    2014-03-07T21:30:50+00:00
    Nothing official I've seen yet, but users reporting 8.1 update delivers at last:
    http://www.surfaceforums.net/forum/microsoft-surface-pro-2/8342-8-1-update-1-fixes-tap-drag.html
    2014-03-08T11:22:45+00:00
    Still doesn't work for me can anyone else comment?
    2014-03-08T13:15:26+00:00
    Have you installed the leaked Update 1 (not just 8.1)?
