With 8.1 update 1, type/touch cover 2 can now perform double tap-drag. All hail lord Microsoft.
Double tap to left click and drag on trackpad
Hello, I was trying to find a way to click and drag by using the Type Cover 2 trackpad without keeping the left mouse button pressed. Most touchpads nowadays register a rapid double click as a "left click and drag" command and, according to the documentation on Microsoft's website, the Type Cover 2 should as well. However, I tried to use the feature both in Desktop programs and UI apps with no success. How to left click and drag without keeping the trackpad's left mouse button pressed?
Edit: called the customer service, and I was told that the team is aware of the issue and that a fix is planned.
Greetings all,
The “Tap, then tap and slide one finger in any direction" gesture to perform a “left-click and drag” is not supported in Windows 8.1 for precision touchpads such as Touch Cover 2 and Type Cover 2.
The “left-click and drag” function can be performed on Touch Cover 2 and Type Cover 2 by holding the left touchpad button down and then sliding a finger in any direction.
We’ll be updating the inaccurate information in Touchpad: A built-in mouse.
158 additional answers
2014-02-22T18:58:33+00:00 The workaround is sufficient for me and I've gotten used to using it like that. I am curious as to why it was removed though? And would really like to know.
No offense meant to the person who made the Autohotkey script, but I don't want MS to think it is an acceptable workaround, and that they don't need to address this issue. It's at best an inelegant hack, that people shouldn't have to use on a $1500+ device.
I've already returned my Touch Cover and TBH, I'm not missing it. Surface Pro works great without a keyboard. Seeing how Microsoft isn't addressing the issue, I encourage anyone to return theirs too.
2014-02-22T22:46:43+00:00 I totally agree, and I also think the autohotkey workaround kind of misses the whole point of this gesture: To enable dragging using only ONE hand/finger...
I think it's crazy that I have to carry a mouse with me to use my brand new, very expensive, top-of-the-line, ultra portable computer... :/
2014-02-23T01:23:43+00:00 I totally agree, and I also think the autohotkey workaround kind of misses the whole point of this gesture: To enable dragging using only ONE hand/finger...
The point of the autohotkey is to be a better option than the Type Cover 2's left click button. It is really hard to use. I agree it is not ideal - double-tap and drag is just expected to work so this is a shame. I do however find that holding down a key on the keyboard and dragging is surprisingly effective and easy to use. But certainly it is still just a workaround.
