Double tap to left click and drag on trackpad
2013-10-25T13:45:34+00:00
Hello, I was trying to find a way to click and drag by using the Type Cover 2 trackpad without keeping the left mouse button pressed. Most touchpads nowadays register a rapid double click as a "left click and drag" command and, according to the documentation on Microsoft's website, the Type Cover 2 should as well. However, I tried to use the feature both in Desktop programs and UI apps with no success. How to left click and drag without keeping the trackpad's left mouse button pressed?
Edit: called the customer service, and I was told that the team is aware of the issue and that a fix is planned.
2014-04-09T01:07:12+00:00
With 8.1 update 1, type/touch cover 2 can now perform double tap-drag. All hail lord Microsoft.
2013-11-21T02:57:03+00:00
Greetings all,
The “Tap, then tap and slide one finger in any direction"  gesture to perform a “left-click and drag” is not supported in Windows 8.1 for precision touchpads such as Touch Cover 2 and Type Cover 2.
The “left-click and drag” function can be performed on Touch Cover 2 and Type Cover 2 by holding the left touchpad button down and then sliding a finger in any direction.
We’ll be updating the inaccurate information in Touchpad: A built-in mouse.
158 additional answers
    2014-02-13T17:41:25+00:00
    I agree. It's not a deal breaker for me either.
    I still like the Type Cover 2 more than the original, even though the original Type Cover 1 has this function. But I sure would love my Type Cover 2 more if it does.
    2014-02-13T20:41:27+00:00
    I agree. It's not a deal breaker for me either...
    Yes, not a deal breaker, but then I'm one of the majority who have use of both hands.
    It was initially an advertised feature, so I don't think they have any choice but to implement it. Well, if common sense had anything to do with it...
    2014-02-13T20:51:52+00:00
    It works on my Type Cover 1 and Touch Cover 1. From what I've read, others say it works on the Touch Cover 2. Is there some kind of hardware limitation that doesn't double touch and drag to work on the Type Cover 2? It's still not working on my Type Cover 2 since the last update (though that was for 2 finger improvements).
    Hope it gets fixed soon!
    Thanks.
