With 8.1 update 1, type/touch cover 2 can now perform double tap-drag. All hail lord Microsoft.
Double tap to left click and drag on trackpad
Hello, I was trying to find a way to click and drag by using the Type Cover 2 trackpad without keeping the left mouse button pressed. Most touchpads nowadays register a rapid double click as a "left click and drag" command and, according to the documentation on Microsoft's website, the Type Cover 2 should as well. However, I tried to use the feature both in Desktop programs and UI apps with no success. How to left click and drag without keeping the trackpad's left mouse button pressed?
Edit: called the customer service, and I was told that the team is aware of the issue and that a fix is planned.
Greetings all,
The “Tap, then tap and slide one finger in any direction" gesture to perform a “left-click and drag” is not supported in Windows 8.1 for precision touchpads such as Touch Cover 2 and Type Cover 2.
The “left-click and drag” function can be performed on Touch Cover 2 and Type Cover 2 by holding the left touchpad button down and then sliding a finger in any direction.
We’ll be updating the inaccurate information in Touchpad: A built-in mouse.
158 additional answers
2013-10-30T02:34:21+00:00 Greetings Dax,
The available gestures can be found here. I'll definitely pass along the feedback however.
2013-10-30T02:48:20+00:00 Greetings idmadj,
Sorry to hear about your experience. Does your Surface have all available updates installed?
