Surface Pro 3 Throttling Solution?
2014-07-06T03:09:34+00:00
Hi! I received my surface pro 3 about 2 weeks ago and so far my experience has been great while surfing the internet, personalizing it to my needs, watching videos, and writing with the stylus.
 I have seen how the surface one and surface pro 2 can handle games on the lowest settings and was very impressed and encouraged to buy the SP3 for light gaming when I have free time and am not using it for work.  However, I am a little disappointed with how the performance on the SP3 drastically drops to less than 1Ghz about 3-5 minutes after I start playing any game or even a less intensive game like Dota 2, Portal, or the newer version of GTA San Andreas (a 2005 GAME) which I bought this week from the Windows Store.  Most of the games I have tried start at 30-60 frames per second but as the heat starts building up, the frame rates drop to 10-15 frames due to throttling... This DOES NOT happen with the surface pro or pro 2 and most people play high end games at 30 frames per second on low settings for long periods even with throttling. I am not able to do that on my surface pro 3... Why? Why is there so much "power" that you can only use for a short time?... Did I just spend $1400 for much less performance than a Surface pro 2?...
I hope that this can be fixed in some way very soon. I really love the surface pro 3 and don't want to return it. But when I play a 2005 game like GTA San Andreas which was ported for smartphones and tablets and the frames drop below 25 after a while... it really gets me thinking...
    2014-08-02T10:37:00+00:00
    Just to add my voice, I picked up an i7 SP3 and am having the same problems as everyone else. After around 50 seconds into any application that uses 80-90% of the cpu, the temperature will rise to around 85 degrees Celsius before being throttled to 1GHz. Im also having the same wifi problems out of sleep where the adapter disappears. It looks like that large premium for the 17 will only help you if you need power in bursts of under a minute...
    2014-07-26T19:01:31+00:00
    I was going to suggest hooking it up to a Nitrogen tank but I don't think that would be practical.
    Don't think there is any way around the issue of heat.  I do believe that is why Microsoft kept the clock rate down so that a person could actually hold the tablet in their hands.
    I think that the i7 tablets will be worse with heat.  We still have over a week before they ship out and us finding out here on the forum with any feedback anybody would post.
    Myself, I plan on getting the i3 for which should not have that problem.  It would be a low performer but at least you can hold it in your hands when using it.
    2014-07-26T17:56:52+00:00
    The only way I was able to solve the issue was by placing my surface in an area where cool air (ac) would blow at it directly cooling the surface at a very high level.  I managed to play Titanfall  with textures on high at 60 FPS for a long period proving that this tablet HAS a LOT of power in it.  The cooling fans are not enough... They should be able to run much faster for the throttling to disappear. The aluminum architecture of the surface absorbs the heat, but it is a very thin tablet PC and because of that, the absorbed heat will still be too close to the cpu so it really does not help with the cooling. That's my guess...
    Other than that if you wanna play mid level gaming and cpu intensive programs, point the air conditioner directly at it and it works heavenly.
    2014-07-26T02:08:57+00:00
    Well, the i3 won't have a heating problem.  It is a low end processor.  The i5 and i7 processors do.  I have both of those in desktops right now and am on the i7 machine right now.  Both are "Haswell".  The i3 is the only processor I don't have.
    The i5 does great but once you put a load on it, the CPU cooling fan kicks in a little longer.  My i7 machine will not operate longer than 4 hours without additional cooling beyond the CPU fan.  That fan only provides 92% of the cooling and requires a chassis fan to assist.
    The problem is the processors themselves.
    The hype that Intel put out on the "Haswell" series made them very popular but it wasn't until they made it out into the world that they didn't live up to it.  You may have noticed that the "Broadwell" came out "very fast" after the "Haswell" series.  That is not typical with Intel.
    So, if you want a real answer, I would suggest to go to intel.com and read through their news feeds.  There have been a few issues with them even though they work great.  My i7 is faster than a speeding bullet.  The i5 works very good as well and both are now running Linux.  The i7, I am reserving it for Windows 9.  The i5 refuses to install the Intel video driver update and thus, I wiped it out and installed Linux on it.
    Now, Linux will put a load on a machine as well.  It has grown over the years and made more robust.  The point I was making about having any problems was in regards to connecting to the Internet which is still a problem with these tablets.  Linux does have the driver for the Marvell AVASTAR adapter.
    Oh, by the way, you will not get a response from Microsoft!  They never discuss any details on anything.
    2014-07-26T01:52:20+00:00
    Let's keep this on topic and see if we can get ms to respond.
    Here is a link to a YouTube video showing the problem exists even under Linux, meaning it's a hardware issue and not a software one.
    http://youtu.be/UbWYQWY-vU8
