Can I connect Surface RT and PC with USB cable?
2012-11-30T00:08:13+00:00
I have a Toshiba Thrive running Android. I can connect it to my PC with a USB cable and access files on my Thrive on the PC. The PC treats the Thrive as a hard drive. Can I connect my Surface in the same way? I have tried and the PC does not appear to see the Surface.
This is a pain, one of the reasons I bought the Surface was to be able to do this type of hard connection and not have to use "iTunes" or the Cloud.
Surface | Other
2013-03-05T02:57:40+00:00
Greetings SaeedR_706,
That is a good question, however I would suggest rather then using the USB cable, to transfer files over your WiFi network to a shared folder on your Windows 7 Laptop.
2012-12-05T00:46:39+00:00
Hello Rrccw,
No, you cannot connect the Surface to the PC via USB. However, you can setup Shared folderson your PC. Once you have that, have the Surface connect to the same network via WiFi and then go into Network from the Desktop app, select your PC and then see the Shared Folders. From there, the Surface should have Read/Write access if you gave the permissions on the PC.
65 additional answers
    2013-03-07T10:29:59+00:00
    I dont have a Wifi Netwrok...I have my Surface RT and my laptop side by side on my table, and I want to physically connect them with a USB-A to USB-A cable inorder to drag and drop files from one to another..Is this possible?
    2013-03-04T10:50:10+00:00
    I want to connect my Surface RT to my laptop which has Windows 7 Home Premium so as to drag-and-drop files from one to another.
    Therefore,
    Can I use a USB-A to USB-A Cable to connect Surface RT to my Laptop..? if no, then which cable will enable me to to do this linkage?
    Look forward to hearing from those who have already connected Surface RT to their Laptop.
    Regards,
    Saeed
  3. Deleted
