Surface Pro Pen pressure sensitivity is not working in photoshop CS6.
2013-02-10T14:58:36+00:00
Surface Pro Pen pressure sensitivity is not working in photoshop CS6. Was anyone able to get their surface pro to use the pen pressure sensitivity? In my photoshop settings when i turn on Pen Pressure for brush settings i see a yellow exclamation mark next to each settings which has to do with pen pressure. If anyone knows how to solve this problem please let me know.
2013-05-09T21:41:01+00:00
http://www.wacom.com/support/drivers
Select windows 8
or use the direct link
http://www.wacom.com/feeldriver
Download the driver dated may 9th ...today.. install and
reboot.
352 additional answers
  1. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2013-02-12T12:11:39+00:00
    Will Microsoft officially confirm or deny that wintab support is coming via a
    new driver? This is not a difficult question.
    Barb
    MVP - Windows Entertainment and Connected Home
    http://digitalmediaphile.com/
    2013-02-12T14:21:26+00:00
    I too hope they add WinTab support instead of just the Ink API. From my previous tests on a Cintiq the Microsoft APIs quantise the input data to a lower resolution than WinTab (i.e. WinTab is better). But I don't have a Surface yet so I can't test what resolution the digitiser has anyway.
    2013-02-12T15:17:30+00:00
    My Surface is out for delivery. I was really hoping to start working on some things as soon as I got this in my hands. Unless Wintab support is being worked on this is just a toy as far as graphic artists are concerned, not much better than an iPad. Even my pogo connect has pressure sensitivity even if it is like working with a used, fatty crayon.
    2013-02-12T15:38:25+00:00
    I just load a copy of Zbrush on my surface pro, and pressure sensitivity is also not working in it. I hope the fix for the photoshop pressure sensitivity also resolves the problem in Zbrush.
