Surface Pro Pen pressure sensitivity is not working in photoshop CS6.
2013-02-10T14:58:36+00:00
Surface Pro Pen pressure sensitivity is not working in photoshop CS6. Was anyone able to get their surface pro to use the pen pressure sensitivity? In my photoshop settings when i turn on Pen Pressure for brush settings i see a yellow exclamation mark next to each settings which has to do with pen pressure. If anyone knows how to solve this problem please let me know.
2013-05-09T21:41:01+00:00
http://www.wacom.com/support/drivers
Select windows 8
or use the direct link
http://www.wacom.com/feeldriver
Download the driver dated may 9th ...today.. install and
reboot.
352 additional answers
    2013-03-20T23:58:10+00:00
    i will donate 50$ after you publish  the plugin or the unsign driver for photoshop right away.
    2013-03-21T00:26:26+00:00
    I have been following this thread daily, as well, after buying a Surface Pro.  I'm a programmer and have done a lot of Windows coding but never drivers.  Looking into this situation, here is what I found:
    This is (apparently) what is required to emulate a WinTab driver.  It contains all the calls and parameters. I would assume it is a bit out of date, but can easily be verified by examining the DLL itself (which I have not done yet)
    http://www.wacomeng.com/windows/docs/Wintab\_v140.htm#\_Toc275759803
    Here is the Surface Pen API used to get values from the pen:
    http://msdn.microsoft.com/EN-US/library/windows/apps/windows.ui.input.inking(v=vs.10).aspx
    If we could make a DLL that presents the WinTab calls but implements them using the Inking API, it should go a long way to getting what we want. Luckily, this guy claims to have such a WinTab-masquerading DLL and someone has already hit him up for the source:
    http://stackoverflow.com/questions/15063775/photoshop-cs5s-use-of-wintab-driver
    I'd be willing to help out and/or work on putting these things together but I am missing knowledge when it comes to making, debugging and installing drivers. Does anyone know more?
    Does this stuff make sense or am I missing something?
    2013-03-21T03:22:02+00:00
    i dont know anything about coding or programming . and i know it's hard so that's why i admit will donate $50 who public a WORKING  driver  . it will bit Microsoft so hard. microsoft make me so disappointed about them few years ago.
    2013-03-21T04:10:50+00:00
    That's good information, though the wintab api is certainly intimidating. What I'd imagine would be a good first step is to wrap the wintab calls with some sort of logging layer and use it on a Wacom tablet. Then draw in photos a bit, and you'd see what parts actually need to be rewritten.
    The Photoshop plugin api isn't looking too promising so far. I don't see it ever exposing a way to do actual brush strokes programmatically.
