Surface Pro Pen pressure sensitivity is not working in photoshop CS6.
2013-02-10T14:58:36+00:00
Surface Pro Pen pressure sensitivity is not working in photoshop CS6. Was anyone able to get their surface pro to use the pen pressure sensitivity? In my photoshop settings when i turn on Pen Pressure for brush settings i see a yellow exclamation mark next to each settings which has to do with pen pressure. If anyone knows how to solve this problem please let me know.
2013-05-09T21:41:01+00:00
http://www.wacom.com/support/drivers
Select windows 8
or use the direct link
http://www.wacom.com/feeldriver
Download the driver dated may 9th ...today.. install and
reboot.
352 additional answers
  1. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2013-03-14T10:27:09+00:00
    even if we have to turn testsigning on through bcdedit (in case Microsoft wants
    to use unsigned drivers as an objection to giving us a test driver that is not
    signed).
    you can read about this bcdedit switch at
    http://msdn.microsoft.com/en-us/library/windows/hardware/ff553484(v=vs.85).aspx
    Microsoft folks, how about a response to this request for a test driver,
    unsigned ok.
    Barb
    MVP - Windows Entertainment and Connected Home
    http://digitalmediaphile.com/
  2. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2013-03-15T13:20:42+00:00
    Hugo,
    how about a beta driver? even an unsigned beta driver? Please give us the courtesy of a prompt reponse.
    2013-03-15T13:31:16+00:00
    Let's not downplay Sketchbook. Its a great program from Autodesk that does its job extremely well for several years now.
    2013-03-15T16:49:55+00:00
    Sketchbook's support of the Ink API is less than ideal - as a temporary stop gap I had to go with ArtRage instead. Sketchbook doesn't support touch pan and zoom without WinTab, and there is a multi-second delay after using the eyedropper tool (a killer for digital painting).
