My Surface Book 2 i7 256gb is experiencing coil whine.
2017-11-21T08:05:28+00:00
Is there anyway to get around this?
Definitely notice coil whine whenever my SB2 is plugged into charging and on high performance mode. I am concerned about this issue as I was hoping issues like these didn't come with such a high price tag.
2018-04-16T18:14:15+00:00
Update 8/1/2018:
Thank you for your feedback. We have published a set of drivers and system updates which helps mitigate this issue. This is now available in Windows Update.
As a temporary workaround, we suggest that when your Surface is plugged into the power supply, click on the battery icon in the Windows taskbar and set the Power Mode slider to either “Recommended” or “Better performance.”
139 additional answers
    2018-02-16T17:29:41+00:00
    I think exchange will only be a loss of time, I've seen posts of people having the same issue, with machines bought in US as well as in Europe with different lot number so we can fairly assume that it's a conception problem. The petition thing however sounds like a good idea. If we could flood their twitter or customer service with reports of the issue, country of purchase and lot number we could have them communicate and take corrective measures.
    2018-02-16T18:28:37+00:00
    I exchanged my SB2 i7 and the coil whine persists. One does get used to the sound but in essence I do find it inappropriate. I guess I should have gone back to the Surface pro i7. It definitely does not have this problem. The SB2is otherwise really a great piece of kit and a joy to use except for the whine.
    I do not support the notion that coil whine is normal. It isn't and I never had a notebook with this problem. .
    2018-02-16T18:41:01+00:00
    I agree. The coil whine noise is frustrating. Its strange how just having the camera app open makes it happen...
    Is anybody from Microsoft would care to give us some explanation?
    2018-02-16T19:32:30+00:00
    I got two of them. One 16/512 and one 8/256. The 16 had awful coil whine ; the 8/256 was quite ok, as long as tou stay in recommended mode or intermediary performance. Once you got in best performance, both got strong coil whine. In the end, i stuck to my 2017 macbook pro and sent both back. You get less graphic performancr and versatility with apple, but quality control is SSSOOOOOO much better than microosft (i have a surface book 1 too and exchanged it three times....).
    i might give he 15 a try nevertheless....
