My Surface Book 2 i7 256gb is experiencing coil whine.
2017-11-21T08:05:28+00:00
Is there anyway to get around this?
Definitely notice coil whine whenever my SB2 is plugged into charging and on high performance mode. I am concerned about this issue as I was hoping issues like these didn't come with such a high price tag.
2018-04-16T18:14:15+00:00
Update 8/1/2018:
Thank you for your feedback. We have published a set of drivers and system updates which helps mitigate this issue. This is now available in Windows Update.
As a temporary workaround, we suggest that when your Surface is plugged into the power supply, click on the battery icon in the Windows taskbar and set the Power Mode slider to either “Recommended” or “Better performance.”
139 additional answers
    2018-06-22T12:05:47+00:00
    Can we please get an official update?
    2018-06-22T15:35:39+00:00
    Hi RDC1969,
    We appreciate your patience with regard to the issue. Kindly monitor the thread as we would update the pinned post once a solution is available.
    Should you have other inquiries feel free to post back.
    2018-06-25T11:04:16+00:00
    I went through 7 devices. All had to same coil whine noise. Until MS provide a fix, you are wasting time in getting replacements.
    In addition to coil whine noises, I noticed that not 2 device are the same. This highlights the poor quality control...
    1. Plastic contour around the screen where the power button seats is loose.
    2. Excessive light bleed
    3. Plastic bumper underneath the base unit warn out
    4. Top section (screen) not aligned with the base unit
    5. Quality control got coil whine noise consistent on all devices :) Well done...
    I have sold my Surface Book 2 privately. I have wasted enough time and money with Microsoft unhelpful online support.
    Microsoft have lost my business and I will be looking for alternatives from now on.  I should have listen to Consumer Reports which recommends against buying any Surface products. Instead, I followed Mr Panos Panay who says the Surface line has no high volume of costumer returns and is reliable... Of course you will say that...
    2018-06-25T11:35:25+00:00
    I can see the twitter #SurfaceBook2CoilWhineNoise is growing... Keep it going guys...
