My Surface Book 2 i7 256gb is experiencing coil whine.
2017-11-21T08:05:28+00:00
Is there anyway to get around this?
Definitely notice coil whine whenever my SB2 is plugged into charging and on high performance mode. I am concerned about this issue as I was hoping issues like these didn't come with such a high price tag.
2018-04-16T18:14:15+00:00
Update 8/1/2018:
Thank you for your feedback. We have published a set of drivers and system updates which helps mitigate this issue. This is now available in Windows Update.
As a temporary workaround, we suggest that when your Surface is plugged into the power supply, click on the battery icon in the Windows taskbar and set the Power Mode slider to either “Recommended” or “Better performance.”
139 additional answers
    2018-05-07T10:21:13+00:00
    as Mentioned on page 6 of this diskussion, benchmarked and tested by others too this will just limit your performance.
    https://www.reddit.com/r/Surface/comments/7kbqhj/surface\_book\_2\_135\_i78650u\_analysis\_throttling/
    2018-05-07T13:00:08+00:00
    "This is normal given the high-powered component and the specs of this model. " Hej Microsoft - you are fooling your customers. .. it is normal??? Are you serious? Are you working with your own products and accept this misbehaviour? It is strange to see all this ignorance from Microsoft. Even more surprising to tell customers its just normal.
    I have never ever experienced coil whining in the past and its just a parody to claim its because of the supper dupper specs of this model. Just do a better job in designing your electronics and test it out seriously.
    Also to Laya Sagi who marks the question as answered (hm??): You are investigating now in April 2018? How did all of your employees (what is it: 125'000 ??) possibly not detect this wining since the Surface Book launch. I am sure some did. So please tell us now how to solve it? Also clearly tell your customers if they can expect a solution? If not please accept your faults and give us a refund or a new improved device wich is just working fine.
    Now i am totally frustrated findining out that the internet is full of comments and audio-samples of Surface Books 2 with 'coil whine'.
    2018-05-18T17:01:47+00:00
    I'm experiencing this issue as of May 2018.
    I ran the Surface Diagnostic Toolkit to ensure i'm on the latest update, but the problem is still occurring.
    I read through the entire thread and don't see any satisfactory answer from Microsoft:
    Can we get a status update from someone at Microsoft?  Will Microsoft release a fix for this issue via software patch?  Should I attempt to replace my Surface Book through warranty?
    2018-05-18T17:10:14+00:00
    Short answer, get a full refund if you can. I went through 7 devices and all had the same issue. If this was something Microsoft could fix through a firmware/driver update, they would have done it by now...
