My Surface Book 2 i7 256gb is experiencing coil whine.
2017-11-21T08:05:28+00:00
Is there anyway to get around this?
Definitely notice coil whine whenever my SB2 is plugged into charging and on high performance mode. I am concerned about this issue as I was hoping issues like these didn't come with such a high price tag.
2018-04-16T18:14:15+00:00
Update 8/1/2018:
Thank you for your feedback. We have published a set of drivers and system updates which helps mitigate this issue. This is now available in Windows Update.
As a temporary workaround, we suggest that when your Surface is plugged into the power supply, click on the battery icon in the Windows taskbar and set the Power Mode slider to either “Recommended” or “Better performance.”
139 additional answers
    2018-03-28T20:34:55+00:00
    Hi Joe - sorry to hear that.  Hopefully people will see my link to the feedback hub or from the hub to this page and between them we'll get some Microsoft attention to this issue (and feedback to us users so we'll know what's going on).
    2018-03-28T20:47:22+00:00
    I searched for Surface Book 2 experiences Coil Whine and couldnt find it in the list?
    2018-03-28T22:20:42+00:00
    My feedback hub now lists a new link (not helpful!):
     https://aka.ms/Ruy7gp
    2018-04-04T21:30:59+00:00
    Wow, I was following this issue for some time now, because I was thinking about getting the 13.5 i7 version for myself. Seems like the issue hasn't been resolved yet. And as far as I can tell the MS support messages have been far from helpful.
    The fact that the SB2 cannot be used in a calm environment without disturbing others makes it useless.
    I will refrain from buying the SB2 now and look for alternatives.
