Monitor stuck on displayport with 640x480
2020-02-02T03:26:26+00:00
Hi all.. Today after I updated my surface pro, my monitor is stuck in a 640x480 resolution. Which is no good with a 49 inch Samsung monitor. If I plug in the HDMI, it works, but, resolution is not that good like it was on the Displayport. Any tips or tricks to get it working again? For some reason it shows 'Flat Panel, 640x480' when using display port, but the samsung drivers when using HDMI.
I am using the surface dock as well. I tried the displayport of the monitor with other computers and it's working fine. Not with surface. Really need help with this one!
    2020-07-15T13:53:06+00:00
    Same here.
    Bought new setup with SP7, surfacedock en samsung C49.
    The workaround with older drivers did the trick
    (for users who can't find the work-arrond link: https://borncity.com/win/2020/02/07/surface-pro-7-laptop-3-fix-for-640-x-480-mode-update-issue/)
    I've spent  +- € 2000,- when does Microsoft create a sollution!!
    2020-07-28T22:28:55+00:00
    Here is the December 2019 bundle for Surface Pro 7. It should include the drivers
    https://download.microsoft.com/download/0/8/b/08b0f0ba-1571-41c0-9b8a-9af8a43681ae/SurfacePro7\_Win10\_18362\_19.103.34215.0.msi
    Here is the November 2019 Surface Laptop 3 Intel:
    https://download.microsoft.com/download/3/f/4/3f4f5dff-b6a9-4006-87aa-142a8e6f77cb/SurfaceLaptop3\_Win10\_18362\_19.112.27190.0.msi
    Just extract all the files with something like: msiexec /a c:\testfile.msi /qb TARGETDIR=c:\temp\test
    and then install the graphic drivers manually.
    Great Find!  Thank you for posting this solution.  It still works as of today.
    2020-08-13T20:50:36+00:00
    I had the same issue with my new Surface Book 3. Just wanted to share my findings in case I can assist someone else.
    TL;DR - Connect using HDMI if possible, avoid DisplayPort over USB-C (at least until Microsoft releases a driver update)
    Full story:
    I have a Dell Latitude 5290 2-in-1 from work, I also bought a Surface Book 3 (SB3) to replace my aging Surface Pro 4. I own a Dell D6000 USB-C dock (cheap DisplayLink dock that is flaky at best with the SB3) and a 1st-gen Surface Dock (also performed pretty badly with the SB3), and wanted to replace both with a better USB-C dock that supported DisplayPort over USB-C since I could now dock my new Surface Book 3 via USB-C vs. the proprietary Surface Connect.
    I decided on the Dell WD19TB (Thunderbolt edition) because the Latitude 5290 supports Thunderbolt, and the dock is capable of falling back to DisplayPort over USB-C for non-Thunderbolt devices (like the SB3). The dock was connected to my Dell U3415W ultrawide monitor (via DisplayPort) and several USB peripherals. Everything worked beautifully with the Latitude 5290 via Thunderbolt, but I experienced the "640x480" issue when I connected the dock to my SB3. I tried manually installing the drivers for my monitor, updating the Intel graphics driver, etc. but the issue persisted.
    A call with Dell support suggested that I had purchased the "wrong dock" (despite the information about it reverting the USB-C being published on their support site) and that I should exchange it for the non-Thunderbolt WD19. I arranged the exchange and waited for the new dock to arrive. Once I received it, I set it up exactly the same way and experienced the same issue...
    I came across this thread and a few others and messed around with the version of the Intel Iris Plus graphics driver installed on my SB3. I saw that other people with the Surface Pro 7 and Surface Laptop 3 had success with downgrading to version 25.x (I do have a Surface Laptop 3 in the house that I may test this out on), but my Surface Book 3 is too new to have an older driver package available. I downloaded the 27.x (newer than the 26.x version on my Surface Book 3) from Intel, but that made things worse - nothing was displayed on the external monitor at all. I also attempted to download version 25.x from Intel, but that package would not install on the Surface Book 3.
    I was about to give up and revert to the D6000 dock (I was getting random USB disconnects when using it with the SB3, but it was better than the 640x480 resolution and it least "worked" with both PCs). I then decided to try connecting the WD19 to my monitor via HDMI instead. Lo and behold everything just "worked". I have read concerns from others that HDMI may not deliver the same quality as DisplayPort, but for my needs I don't notice any discernible difference. Perhaps if Microsoft gets their act together on fixing the driver issue I will revert back to DisplayPort (after all, it would just be a simple cable swap), but for now I am just happy to have everything working as expected.
    Hopefully this helps another SB3/SL3/SP7 owner out there!
    PS: I also strongly suspect that the WD19TB would have worked just fine if I had switched to HDMI, but I can't confirm that as I didn't attempt that when I had it in my possession. Now I regret exchanging it since I can't take advantage of the Thunderbolt connection on the Latitude 5290. Thanks Dell support...
    2020-08-13T23:27:28+00:00
    Yes I can confirm that HDMI ports of non surface docks work without problems. I just realised today that in my Lenovo thunderbolt gen 2, the display ports are working again properly. I dont what has changed. Now I dont need a solution to this problem.
    2020-08-17T15:52:45+00:00
    Not sure why we need to find fixes for Microsoft's problem - or rather why they don't take this solution and roll it out to users.  I am waiting for them to fix is as I still think there is funny business in advertising the MS dock to work with multiple monitors with the SP7.
    That said, I had high hopes the issue will be solved when my SP7 got the Windows 10 2004 update.  But, no, my second monitor still sits with a black screen and does not connect (display port on the dock to HDMI).
