New firmwares and system components just came down to my Surface Pro 7.
Fingers Crossed for everyone!
Hi all.. Today after I updated my surface pro, my monitor is stuck in a 640x480 resolution. Which is no good with a 49 inch Samsung monitor. If I plug in the HDMI, it works, but, resolution is not that good like it was on the Displayport. Any tips or tricks to get it working again? For some reason it shows 'Flat Panel, 640x480' when using display port, but the samsung drivers when using HDMI.
I am using the surface dock as well. I tried the displayport of the monitor with other computers and it's working fine. Not with surface. Really need help with this one!
So did it work?
So is there any new update?
Its alright that you are proactive about whether someone is following the code of conduct and if there is any violation.
But taking hard-earned money from people and not offering the promised service, that too in complete silence and apathy, is also a violation, but now of moral rules.
Funny how this question is marked as Answered when it clearly isn't!
Anyways, I've had a similar issue and I was jumping between various threads to find a workaround (yes a workaround! not a fix) where I used a USB-C to Display Port HBR3 cable to get the 5120x1440 resolution on my 49' Samsung external monitor from my Surface Laptop 3 with Windows 10 2004 Enterprise Edition.
Check here for more details on the drivers I tested (and failed):
It's July 9th.
Over 5 months.
Any reason this hasnt been fixed yet?
