Microsoft Surface Pro (2017) BSOD PDC_WATCHDOG_TIMEOUT pdc.sys with Trend Micro Anti Virus
2017-12-16T02:29:14+00:00
I've been getting bluescreens for a few days now after a while of doing nothing.
The tablet is currently unused next to me but is on and the display is off, eventually comes just the said BSOD and the part restarts.
Have current Surace Pack on Win10 and current updates.
What could be the PDC_WATCHDOG_TIMEOUT?
The triggering file is pdc.sys.
2018-01-29T05:01:53+00:00
My Company is experiencing the exact same issue with our Surface Pro Fleet of Devices (1796 & 1807); Trend has been fairly helpful but still yet to confirm a proper fix & it's currently not on the Developers Radar for future fixes.. The "workarounds" suggested & that I've deployed to a few Surfaces are proving successful.
Trend Micro's Response:
As per checking deeper on the DMP files that was collected, as per our Developers; the issue is because Behaviour Monitoring is unable to handle events from sleep mode. So indirectly, it leads to PDC.sys, or DAM.sys to BSOD.
--CUT--
PROCESS ffffbe830f8e8640 SessionId: 0 Cid: 196c Peb: d48258b000 ParentCid: 0368 DeepFreeze DirBase: 126388000 ObjectTable: ffffce8bc4bc6480 HandleCount: 2212. Image: TMBMSRV.exe
--CUT--
Suggested Action Plan to apply for testing, provided by Trend Micro:
  1. Rename AEGIS drivers and create a folder with same name
c:\windows\system32\drivers\tmcomm.sys
c:\windows\system32\drivers\tmactmon.sys
c:\windows\system32\drivers\tmevtmgr.sys
(ps: Take tmcomm.sys for example, rename it as tmcomm.sys.bak, then create a folder named tmcomm.sys)
  1. Create the following registry key entry:
[HKEY_LOCAL_MACHINE\SOFTWARE\TrendMicro\aegis]
PowerMonitorTime=dword:0x10
Still awaiting for further development & feedback from Trend but have yet to experience a BSOD with the above mentioned Action steps followed.
Note our case is still opened with Trend Micro, I'll post updates as they occur.
2018-01-03T12:18:56+00:00
I uninstalled Trend Micro Anti Virus and the problem went away.  We are now using Symantec Antivirus.
2018-03-14T10:21:25+00:00
I can confirm applying just the registry key from the above posts fixes the BSOD/Crash on the 3 Surface books I have updated to 1709 with the latest driver pack 18_015_00 16299 (64 bit)  .
I have logged the call with Trend to find out what exactly the key does before I roll it out and if there is a fix/patch due to be released.
52 additional answers
    2018-03-28T09:08:20+00:00
    Not taking it personally I just think it might be unrelated to the pdc.sys BSOD we're discussing here..
    "Intel(R) Content Protection HDCP Service" issue is more than likely related to: Intel HD Graphics 630 & the APC_INDEX_MISMATCH with the BSOD: igdkmd64.sys.
    https://communities.intel.com/thread/121512
    2018-03-30T12:06:55+00:00
    It seems worked for me, one system stopped BSoDing after disable "Intel(R) Content Protection HDCP Service".
    Personally agree it is just a workaround,
    I'll try to update the Intel Graphic Driver 23.20.16.4901 to newer version or "disable CS" later
